I recently got an HDMI cable to connect my upconverting DVD player to my television, and it was working fine for a few days. Suddenly I plugged the cable back in today and I am getting no audio whatsoever. I did not change any settings and I double checked to make sure everything was in order. I have been switching the cable back and forth between DVD player and my laptop, but I don't see how this could suddenly affect the sound. If anyone could help it would be much appreciated! I did buy the cable off ebay but as far as I know it's new and in good shape.
Results 1 to 16 of 16
Try disconnecting all electrical power from both DVD player and TV for 5 minutes. Then plug everything back in and try again. Sometimes a simple reset will do the trick.
I did exactly that and it worked. Strange, but at least it's fixed. I'm still curious as to why I suddenly lost audio though.
Do you have a Samsung HDTV by any chance? I do and their HDTVs are kind of infamous for having HDCP sync issues. It wouldn't surprise if this was more of the same.
Don't turn it off. Unplug the TV (and it probably wouldn't hurt to unplug whatever's on the other end of the HDMI cable, as well) from the wall power socket/power strip/etc. for about five minutes to half an hour, then plug the power cable(s) back in, and see if the problem's still there.
If cameras add ten pounds, why would people want to eat them? -
Make sure your DVD player is set to output audio to HDMI not to its digital coax or optical port.
I've run into this problem occasionally and I solved it by unplugging the HDMI cable from the DVD player and then re-inserting the HDMI plug in the DVD player.
Does your laptop still play audio?
Have you tried a different DVD player? -
dvd player plays divx movies and uspaclaes no prob its when it comes to rented or purschased dvds i get the non hdcp compliant message
Being unable to upscale retail(rental) DVD's is not unusual. the copy protection is intended to prevent you from upconverting. Your DVD player is the problem. What brand and model is it?
HDMI cable - from computer to TV, no audio
By Zetti in forum Software PlayingReplies: 15Last Post: 12th Dec 2011, 12:30 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33 -
HDMI Cable - Audio ???
By blinky88 in forum ComputerReplies: 8Last Post: 27th Apr 2011, 08:23 -
No audio on TV after hooking up laptop with HDMI cable.
By jordy2324 in forum ComputerReplies: 5Last Post: 27th Jul 2009, 20:23 -
audio with hdmi cable?
By eligen in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2009, 01:35
