4.7 GB blank DVD's usually have 120 minutes printed somewhere on the container.
With CD's @ 74 & 80 minutes, this refers to the exact recording time of an audio (redbook) CD that
will fit.
With DVD, what does the 120 minutes refer to?
Actually, nothing at all. You can put eight or more hours on a DVD. But generally, two hours or less video on a DVD-5 will give you good quality. The bitrate used is much more important than the playing time.
That's what seems curious to me. As you mentioned, I (and just about everybody) have been making DVD's
with less or more time depending on how we chose to encode them.
That the 120 minutes means nothing, and that it serves to confuse newbies,
seems odd. That's why I thought that there may have been a more precise, albeit obscure, meaning to it. -
I thought it was a reference to the SP mode on a recorder which invariably gives you just over 120 minutes on a disk.
Not sure which came first, but 120 minutes has come to represent SP type quality. That said, it is still an arbitrary number based on a reasonable average bitrate/quality trade off. I wonder if they would have caused more or less confusion by not putting a running time on blanks at all.
Read my blog here.
I think coming up with (and promoting) 120 mins and "SP" quality is a good thing. Average consumers don't want to think much more than that. Of course we "experts" know we can fit more on a DVD but we know what we are doing. Average consumers using CBR really don't need any more settings than HQ, SP, and the other lower settings. That's what the PC (and VBR) is for, right?
Darryl
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 16:32 -
4.6G 120 minute disk giving only 113 minutes at 27% quality Why?
By Emerogork in forum MediaReplies: 22Last Post: 12th Aug 2009, 11:05 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:20 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 21:55 -
burn 120 minutes movie in 1 CD?
By hackerzlab in forum Newbie / General discussionsReplies: 18Last Post: 9th May 2007, 10:16
