Great app deank! Question to all - every thing I have done with it (builds 740-751) is to convert dvd compilations to blu-ray compliant, so like 4 movies to BD25 or even an entire television season. Every time though, the audio comes out much softer than the original, not nearly as loud. I have to crank the volume practically all the way up to hear it (and I am not going deaf). It is all ac3 going in, and I do not transcode to different properties, just the format conversion. Any and all help to fix the audio issue I am having greatly appreciated (would like audio coming out to sound as similar to audio going in as possible). Thanks!
If your original DVD audio is AC3 (with lower or equal bitrate to the one set in Non HD audio bitrate box) multiAVCHD does not touch it and you're getting the original audio track.
In case the audio is re-encoded then it is another case, although it shouldn't come out softer. Which one is it?Laugh and the world will laugh with you. Cry and you will be alone -
Original DVD audio is AC3, and usually 5.1. I do not have any HD audio on them but the bitrate box you refer to is at 448kpbs for non-HD audio to AC3 and HD audio to AC3 at 640kbps. Volume is coming out about 50% quieter (or so). Thought it might be a volume gain issue, but I do not see a setting for that. Though it may be more than a volume issue because when I do crank it up the quality does not seem as good as source.
A log will be helpful, but you can replace 448 with 640 and then it is guaranteed that DVD audio will not be converted.
ffmpeg: getting quality loss of avi when adding audio back in
By vidgem in forum AudioReplies: 2Last Post: 15th Mar 2012, 23:39 -
How to add selectable audio to a video without quality loss
By m.eshi in forum EditingReplies: 2Last Post: 27th Aug 2011, 09:09 -
MultiAVCHD mkv to 25gb bdr
By VOYAGER2009 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Apr 2011, 08:37 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 21:48 -
How to split audio for editing without loss of quality in video?
By anindyanuri in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2008, 20:26
