I don't know what happened. I was just going to try capturing video for the first time on a new Windows 7 PC. Plugged a 4-pin-to-4-pin firewire cable to the HV20, then to the appropriate port on my PC. The HV20 started emitting smoke from the cassette compartment and I heard the ding of it shutting off. I immediately unplugged it, but it was too late. HV20 won't turn on. Anyone else have a similar experience? I just reported it to Canon customer service, but if they're like other customer service departments, I'm pretty sure I'm not going to get anywhere. I doublechecked the setup of the firewire connections inside the PC, and looked in the Canon manual to make sure 4-pin-to-4-pin is supported (it is). I just don't know what happened and I'm so bummed.
Results 1 to 11 of 11
Just getting my feet wet!
a firewire cord will not do this.sound like a fuse went badThe HV20 started emitting smoke from the cassette compartment
extended warranty ? -
like mja said a 4 pin firewire cable has NO power only data lines. if yours does you hooked up the connections wrong inside your computer. not canon's fault.
Thanks for the responses. I did confirm that the firewire bracket is connected correctly to the motherboard, but MJA, could you explain what you meant by a fuse? Do you mean a fuse inside the camcorder?
Just getting my feet wet! -
you'd have to disassemble the cam to find the circuit boards and look for burned parts.
before you connect anything else to that firewire port i'd check the 4 wires with a voltmeter. if there is any current, positive or negative, there is something wrong with it.--
Pinouts for the 4-pin and 6-pin Firewire cables:
http://www.interfacebus.com/Design_Connector_Firewire.html
4-pin has no voltages; 6-pin, up to 30 v.
Firewire capture fom Canon HV20
By johnwc in forum Newbie / General discussionsReplies: 8Last Post: 6th Jul 2010, 10:59 -
Canon HV20/HV30
By Tyler2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 31st May 2008, 14:43 -
Canon HV20 PAL vs. NTSC
By W_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 30th Jan 2008, 17:15 -
CANON HV20
By onionfish in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2008, 17:28 -
Capturing with the Canon HV20
By seven_deuce offsuit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 33Last Post: 2nd Nov 2007, 23:48
