  1. Hi guys
    Is it possible to use ripbot with coreavc instead of ffmpeg? i'm having coreavc in my pc and strongly feel it works much better compared to ffmpeg (i used to have ffmpeg before). Now this ripbot won't install unless i install ffmpeg. any ideas?
  2. CoreAVC doesn't decode any differently from ffmpeg, so it wouldn't improve the encode quality anyway. Any decoder decodes the same image, unless it's buggy.
  3. Originally Posted by creamyhorror View Post
    Ok, but will i be able to install and use ripbot with coreavc or should i use only ffmpeg?
  4. Mod Neophyte redwudz's Avatar
    USA
    I have CoreAVC, RipBot and ffmpeg on the same PC and haven't noticed any conflicts or problems.
    I think to have RipBot use CoreAVC instead of ffmpeg, you would have to rewrite the RipBot script that runs the program.
  5. Originally Posted by redwudz View Post
    All right. Thanks mate!
