    Sep 2009
    Denmark
    Hi.
    I´m having trouble converting DTS to AC3, to make MKV audio smaller size, to fit DVD5 in PS3 with AVCHD structure.
    There are a lot of easy programs doing DTS to "something", and the same with "something" to AC3?!
    It can´t be a fact that there is no such easy software that does the hole job at once, without exotic filters.
    Please help with an easy and simple tool for this?!
    Apr 2004
    Miskatonic U
    MultiAVCHD can do this. If the video is compliant it won't be converted. Click on the Audio tab and look at the settings at the bottom.
    Read my blog here.
  3. Hi,
    There is a Popkorn program...that should do it..
    Alternatively you could demux dts stream,convert to ac3 using DAudioK the remux the new created ac3 with tne video file.
    Happy converting,
    M
