I downloaded smplayer-0.6.8-win32.exe which should include mencoder.exe.
I found no mencoder executable in it.
I downloaded FFmpeg-0.5.1-svn-22140.7z.
I tried using a batch file I found in this forum.
It had this:
set PASS1OPTS=-vcodec xvid -b 930kb -bf 1 -an
in one line to set the pass one options.
I get this error:
Unknown encoder 'xvid'
Obviously I need to download codecs.
How do I get these codecs and mencoder.exe?
Thanks and have a nice day,
Sherman Kenney
There is more to life than meets the microscope. -
I have used SMPlayer while ago, as far as I know SMP comes with many flavors.
Try using complete version which comes with shared libraries too, probably you will not need anything more.
If you still need mencoder and ffmpeg, download latest versions from videoHelp.
Mplayer and Mencoder: https://www.videohelp.com/tools/MPlayer
FFMpeg: https://www.videohelp.com/tools/ffmpeg
Latest versions are always better and improved (bug-fixed).
VideoHelp still have a nice option for all OLD Versions too!
I personally use VLC now, and LUV VLC.Last edited by Bonie81; 9th May 2010 at 01:27. Reason: addition
I used the link on this site to get ffmpeg. It has a text file, the executable, and a docs folder with html files.
I had to use -ac 2 instead of -ac 3.
This implies I don't have the codec for mp3's.
Are all the codecs in the exe or is there a way to get all current codrcs?There is more to life than meets the microscope. -
ffmpeg doesn't use any Windows codecs.
Note that there are different versions around and that there are small differences in the command syntax. So you may need to modify any batch files you find.
The docs should tell you the options for your version. Also you can type
ffmpeg -h >ff.txt to get its basic options in a text file.
ffmpeg -formats >formats.txt will list the available formats and codecs it supports. -
Here you will get what you want fore p3 or p4
MPlayer and Mencoder : http://oss.netfarm.it/mplayer-win32.php -
Hello,
The non-gui concole mencoder.exe compiled with mingw32. This is used by Win/Dos versions of Zsnes Super Nintendo emulator (http://zsnes.com) for dumping and encoding the video frames captured is super nintendo save states to a standard pc video format.
The last version wich includes mencoder.exe that I found at:
ftp.mplayerhq.hu/MPlayer/old_stuff/win32/MPlayer-mingw32-1.0pre7.zip
ftp.mplayerhq.hu/MPlayer/releases/win32/MPlayer-mingw32-1.0rc2.zip
see: http://board.zsnes.com/phpBB3/viewtopic.php?f=2&t=11810
Ceers.Last edited by OryNider; 8th Nov 2010 at 05:23. Reason: added zsnes site url
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 33Last Post: 6th Aug 2014, 16:45 -
60i and ffmpeg or mencoder
By wiz561 in forum Video ConversionReplies: 9Last Post: 9th Jan 2012, 17:02 -
fFMpeg or Mencoder Help! :(
By Shohag_ifas in forum Video ConversionReplies: 0Last Post: 4th Feb 2011, 17:52 -
H.264 ffmpeg vs mencoder
By tommcd64 in forum Video ConversionReplies: 1Last Post: 6th Jun 2010, 13:22 -
ffmpeg mencoder x264
By mrcoolekin in forum Portable VideoReplies: 1Last Post: 16th Jan 2008, 07:49
