I want to encode my DVD movies in H 264 format, but I want these to be as small as possible and as HD as possible. Kinda like SecretMyth Ripped Movies. He encodes his movies in multiple passes, but I can't find any software which gives me the options to select the bitrate, passes, audio channel, resolution in one? Does anyone know of such software?
You only need multiple passes if you need a particular file size. Otherwise, save your self some time and just use single pass constant quality encoding. CRF in x264. You always get the quality you specify. I believe all the packages Baldrick mentioned support CRF encoding.
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Encode my H.264/AC3 .M2TS HD PVR video to Xbox friendly format?
By hopeSOLO in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 13:29 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
Blu-ray encode to h.264 - Audio Problems
By sangood in forum Blu-ray RippingReplies: 5Last Post: 25th Apr 2008, 07:32 -
h.264/MPEG-4 to 2-pass XviD (.avi)
By lalala in forum Video ConversionReplies: 4Last Post: 9th Sep 2007, 21:19
