Hi ,
I've splited the sound tracks from a movie ( movie was a Bluray of 1980i and I encoded it to 720p)
The result : one LPCM of 2 GB ; one DTS of 987 MB and one AC3 of about 900 MB
How can I convert these files to smaller ones ???
What soft/softs can I use ?
I wanna resize them up to 200-300 MB each , doesn't matter the quality , I know that...
Thanks !!
Results 1 to 11 of 11
Many Thanks yoda 313 !!!
but there is a problem....I tried many times to install that famous eac3to alone , without other softs and I didn't succes
or maybe I didn't found out the right soft , or the right site.... I didn't found a graphical interface for it coz I don't know to work in DOS , just in windows.....
can you help me ??
Btw , I have installed Ripbot 264....can I use it for such encodings , just for sound trackes ?? -
@guns1inger
THX for your answer ,but PLS , be more specific !!!
I didn't understand your English at all
Can you explain me in details and using an adequate proper English !!!
Thanks !! -
GUI = Graphical User Interface = a frontend for the command line application. https://www.videohelp.com/tools/eac3to#download
THX Baldrick !!
I've already downloaded this : http://forum.doom9.org/showthread.php?t=125966
I've tried to install it...I installed and at click on .exe file it rans several files in DOS and stopped...
How do I find the interface?? that one from your example in the right side ???
I need an interface to operate !!!! -
Included in https://www.videohelp.com/download/eac3to318.zip . And run yr_eac3_more_gui.exe .
I managed, but does it require additional settings somehow?
...look how it looks ..
bottom right corner can not see what is under REMOVE ...
Perhaps you need to run your display at a higher resolution to see all the options.
What I meant about the audio tracks is that many discs will have an LPCM, AC3 and DTS version of the same track. You only need one of these if the content is the same in all three.Read my blog here.
It seems an interface for DOS , not for windows but that's so great ...
My screen resolution is at maximum....
In this case there are different tracks (music, sounds of nature, the narrator's voice)....
Any suggestion for resizing the interface ?? like in exemple from the site ??? There has a normal size....
lpcm to dts/ac3
By bigman1992 in forum AudioReplies: 9Last Post: 8th Dec 2010, 01:48 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
Problem converting DTS-HD to LPCM
By seplant in forum Blu-ray RippingReplies: 4Last Post: 3rd Mar 2010, 20:06 -
Converting DTS to AC3
By badreligionhead in forum AudioReplies: 3Last Post: 18th Aug 2009, 00:07 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09
