I've trying to enhance my anime using sharpen filters.
however, even though the edges are so much more distinct now, its generally jagged.
do you guys know any filter that works like the 3d anti-aliasing?
thanks in advance..
was it jaggy before or after sharpening?
sharpening should accentuate ringing, not aliasing
if you are truly describing aliasing, then it's tough to get rid of without blurring (which counteracts your sharpening). Some filters you could try
http://avisynth.org/mediawiki/External_plugins#Anti-aliasing
if it's not aliasing that you're describing, then post a screenshot or describe it better -
Not sure what you are asking.
What is your source? Antialias is used to fit a sharp high quality source into a limited bandwidth. It is not a good way to correct an over sharp source.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I assume you're using Avisynth
LimitedSharpenFaster seems to give a smoother edge than other sharpeners. Not so powerful though. I use it on old VHS captures at strength between 100 and 225.
Doom9 thread
But I don't do much cartoons. For that see Scintilla's Guide to AVISynth Postprocessing Filters
Cant get rid of aliasing
By killerteengohan in forum RestorationReplies: 7Last Post: 8th Feb 2012, 00:33 -
Please suggest good AviSynth Anti-Aliasing & Rainbow Remover scripts
By VideoFanatic in forum RestorationReplies: 0Last Post: 30th Nov 2011, 07:54 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 22:28 -
Anti-Aliasing Photoshop titles
By kippard in forum EditingReplies: 0Last Post: 6th Feb 2009, 18:01 -
Converting *.SRT to *.SUP subtitle problem (anti-aliasing).
By shay86 in forum SubtitleReplies: 1Last Post: 29th Oct 2007, 03:30
