  1. First of all Hi everyone
    i have a problem with popcorn audioconverter (v1.82.1)
    When i click common directory's browse(for mkvtoolnix), program just stay locked
    and i have to make the crtl+alt+del to shut down the program
    i made the indivicual locations (mkv info.exe, mkv ectract.exe, mkv merge.exe)
    but can't do the common directory (mkvtoolnix) it just locked
    what am i missing?
    waiting for your help
  2. noone can help?
    Jan 2004
    not sure that you're missing anything. I have mine set up with individual locations, i.e. C:\Program Files\MKVToolnix and then to the corresponding app. All works fine for me. Try an uninstall & a reinstall; run as administrator or even select compatibility to XP. Post back if that doesnt work. Best of luck. P.S Its not just the simplest of things and you dont have mkvtoolnix installed???
