I want to remove commercial spots from this 1.5gb avi files I have of 1 hour episodes. What is the best program out there that can accomplish this preferably without having to recode, if not, it's ok if it needs to recode. The program can be either free or commercial ($150 or less) as long as it can do the job without getting the audio&video out of sync. To me, maintaining the picture quality is very important (therefore the re-coding usually degrades pic quality which is why I prefer not to re-code unless necessary)
I am currently recording in AVI format but can also record in MPEG format as well.
Thanks.
_____________________________
Thank God For Jesus Christ!!! -
what kind of avi? use gspot or mediainfo
virtualdub or avidemux should be able to handle most types of video in avi container , using direct stream copy mode (just cutting sections out, no re-encoding)
Live streaming - commercials & overlays
By adam619 in forum Video Streaming DownloadingReplies: 1Last Post: 9th Dec 2010, 11:27 -
Software TV Studios use to edit/cut splice logos & commercials etc....
By Moontrash in forum EditingReplies: 11Last Post: 14th Oct 2010, 23:52 -
Security bits in FAT & NTFS?
By G)-(OST in forum ComputerReplies: 9Last Post: 22nd Aug 2009, 15:16 -
viewing mpeg2 (vob) timeline & removing commercials
By rancid in forum EditingReplies: 11Last Post: 30th Jan 2008, 05:11
