    May 2010
    Sheffield UK
    Hi guys!
    I am not a techy so please bear with me if I sound a bit dumb!
    Right, so I DL AVStoDVD to convert some files I DL to be able to burn them to DVD.
    I can add the files but get an error message saying
    "process aborted during title 1 video encoding operations"
    Oct 2005
    666th portal
    ok it's your first post and you obviously didn't read the rules. from now on don't indicate, post or even hint what you are having a problem with is an illegal file. no help will be given and you risk being banned. you might want to check the LOG FILE <C:\USERS\TRESS\DOCUMENTS\DVD_4.LOG> FOR MORE INFO though
    May 2010
    Sheffield UK
    The log is what I just posted isn't it?? Huh... no idea what I am doing!
    Oct 2005
    666th portal
    i think it writes more than one log file. in different places.
    May 2010
    Sheffield UK
    thanks for the help but i still have no idea what's wrong with it
    Oct 2005
    666th portal
    the log you first posted didn't list any errors. it just said to look in the dvd_4.log is there anything in that log?
  7. @tressls
    making the assumption that you have downloaded the 'Installer' version and you have installed ALL the programs in the Istaller package (just follow the Installer steps), make sure you have a good directshow codecs (like ffdshow) installed as well.
    You can find the project log file in the output folder you selected in AVStoDVD GUI.
    Bye
    MrC
    AVStoDVD Homepage
