MKVs remuxed by MKVmerge are not accepted by my Seagate player. The same files will play in my WD player but they take longer to load than HD MKVs made with MakeMKV or HD Fab. So there is something about MKVMerge that my players don't like. Is there another easy to use remuxing program? To make sure It was MKVMerge that was the problem I demuxed an HD MKV that did play into it's video and audio components and just remuxed them.
and....the remuxed version didn't play.
Any thoughts?
Tony
Since my original post I have tried most of the versions of MKVToolNix with the same result. The resulting MKV takes about 15 seconds to load in my WD player( normal is 1-2 seconds) but the MKV plays just fine once loaded.
However, my Seagate Fat+ doesn't have the patience to wait for loading.. it just freezes up. I tried AVI demux without success.
There is no problem with the demuxing it's just that the remuxing file for MKV toolNix (MMG.exe) causes problems for me.
As I mentioned originally I did take a working MKV file and without changing anything in the file just ran it thru MMG.exe and the new file didn't work
Am I doing something wrong or are there settings in the program that I am unaware of?
Tony
Issue With D-Link DNS-321 & Seagate 2TB Seagate Barracuda
By RKelly in forum ComputerReplies: 0Last Post: 25th Dec 2010, 21:52 -
MPEG2 files of VOB2MPG not accepted by ATI AVIVO video converter
By 33M344 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th May 2010, 13:53 -
How to have more than 1 external subtitle play on the WD or Seagate player?
By cal_tony in forum SubtitleReplies: 0Last Post: 20th Mar 2010, 13:51 -
Gom player and MKVmerge v2.70 and above
By nasdravi in forum Software PlayingReplies: 2Last Post: 9th Jun 2009, 01:42 -
Seagate Disk Wizard files invisible to Windows
By bevills1 in forum ComputerReplies: 0Last Post: 4th Apr 2009, 11:08
