Hello!
The thing what I'm doing is that I use VLC to stream a web cam on a HTTP protokol in the lokal network and then I capture it from the network with FFMPEG that convert's it into a MPEG-2 transport stream and send it back on the networ via the UDP protokol on a IP address.
So I want that WireShar record all the traffic on HTTP and UDP protokols so that I can see what the two programs are sending on the network and if it is possible to see the 188 byte packets goin over the UDP protokol.
So please tell me step by step what I must to enable on WireShark that this will work.
Hope you understand what I mean?
	Uummm... I sort of understand what you mean but this is a video help forum not really a networking forum. All you need to do is capture then filter to what ports you are sending on.
 Also VLC can send in a TS container and UDP directly there is no need to do the two step that you are doing. I could tell you how to do this step by step but if you don't know how then I'm am afraid that the data you obtain will be beyond your understanding too.
	Thanks for the reply. But I found it myself. It works great. I made a mistake in the way of capturing
  Wireshark Antivirus...anyone know how to remove?By BLSAMPLES in forum ComputerReplies: 26Last Post: 6th Sep 2010, 09:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
