Hi everyone, I wondered if someone could please help me.
I wanted to connect a Portable DVD player to my Sony A300 DSLR camera so that I could review my photos on a bigger screen other than the camera screen.
I wondered what brand and model would have capabilities of doing this, I think it would need a USB port and In and Out video outputs but I am not sure.
The DVD player would need a composite or S-Video input that matches your camera's output.
Portable DVD players usually don't have USB ports.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Does it really have to play DVDs, or do you just want a thing that has a bigger display than your camera, as well as the ability to play files transferred from your camera? If that's all you really need, then I recommend a little netbook or something similar. I regularly see them on sale at surplus places (like mwave.com) for less than $150US. They make fine portable media players. Plus, the built-in WiFi connection allows you to upload vids with ease (to say nothing of the usual netbook functions).
If you insist that the thing be able to play actual, physical discs, then you're going to have to get a full-blown laptop. I know of no portable DVD players that have a USB connection. That doesn't mean that they don't exist, but it probably means that they are very rare (= expensive).
If you don't need to transfer files, and do not need to play actual discs, then many portable DVD players will probably do what you want (which, in this case, would be to act as a dumb display). Many models have external video input ports (S-vid or RCA).
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Portable DVD player without LCD
By JN in forum Portable VideoReplies: 4Last Post: 6th Jul 2010, 02:52 -
Portable DVD Player Help
By eastpole in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2009, 11:39 -
Recommendation for Portable DVR for Infrared Camera
By cabezon in forum Portable VideoReplies: 2Last Post: 28th Sep 2009, 12:50 -
LG DP271 portable DVD player
By coatcheckcop in forum Newbie / General discussionsReplies: 0Last Post: 8th Feb 2009, 06:42
