    May 2010
    Brisbane, Australia
    Does anyone know for sure if this device will allow a straight thru connection from the PC to a AV Sender unit without any capture interference.
    I wish to send video from my PC to a AV Sender Unit and do not need any sort of capture function. It just needs to act as adapter ONLY. This is because the PC has no S_Video connector.
    Any help appreciated.
    Lee
    Aug 2006
    If you want to use the Easy Cap USB to connect your PC to the AV sender, it won't work. Capture devices and the software that they use are for getting video into your computer. They don't function in the opposite direction.
    The picture on the TV won't look great, but a scan converter (also known as a PC to TV converter) would work if the PC has a VGA port. They convert the video signal from the VGA port to a TV-friendly format and have composite or S-Video ports to connect to the the AV sender.
  3. How are you connecting the av sender unit to the PC??
    I presume the set up you want is
    USb capture -> PC -> av sender
    The usb capture will have some software to show the captured stream, and probably to set the duration of the recording.
    I very much doubt that this is a viable way of doing what you want.
    The electronic components of the power part adopted a lot of Rubycons.
    May 2010
    Brisbane, Australia
    Many thanks guys your info was most helpful.
    Lee
