i have this .avi file which got corrupted (bad frames). it was video file which i deleted by accident. i ran testdisk to recover that file but i cannot play that file any more. i tried many recovery software but i am getting same thing.
I downloaded virtualdubmod, divxfix, avirepair etc but none of them are able to repair or fix it. getting bad frame error or unknown .avi file when trying to convert or repair file.
also tried using Tenders V-Dub MP3 Freeze VBR Audio and Bad Frames Guide
https://www.videohelp.com/forum/archive/tenders-v-dub-mp3-freeze-vbr-audio-and-bad-fram...e-t142555.html
but its not recognizing .avi file.
any idea.. video is around 1gb. any other suggestion or tips will be helpful
thank you
You can try viewing it in VDMod's Hex editor, but that big of file may be a bit much to handle. But I would look through the contents and if it's mostly zeros, probably nothing to recover.
If just the headers are messed up, you might be able to replace them with headers from a similar file, but not likely.
And welcome to our forums.
thanks for the reply. below is the header data i got from GOM player. everything is Zero.
So i cannot recover file ?
Thank you. New member started with disappointment
Header Data :
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ -
I would say the file is gone.
Try running the same program on a known good file and you will see the difference.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 12:39
