I am using the guide from Mil0tis going from bd to dvd5. I have done this many times but having trouble with this one It's "IMAX - Under the Sea". I have the latest recommended versions of all the software. I have cut and pasted the window from BDR showing the errors. I am wondering - are there are some movies that only like certain versions of software? I don't understand the errors saying "wrong version. Any help would be great.....
[20:58:14] BD Rebuilder v0.33.06 (beta)
- Source: UNDER_THE_SEA
- Input BD size: 8.75 GB
- Approximate total content: [00:40:51.490]
- Target BD size: 4.27 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- One Pass ABR Mode enabled
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[20:58:14] PHASE ONE, Encoding
- [20:58:14] Extracting A/V streams [VID_00020]
- [21:02:13] Reencoding: VID_00020 (1 of 1)
- [21:02:13] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 23.976fps, 58,777 frames
- Bitrate: 13,135 Kbs
- [21:02:13] Reencoding: VID_00020, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.33.06 (beta)
- AVISYNTH Version: 2.6.0.1, not recommended version
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3370, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[21:02:17] - Failed video encode, aborted
If those errors are correct:
- AVISYNTH Version: 2.6.0.1, not recommended version (V2.57?)
- HAALI Splitter: Isn't recommended version (V1.9.42.1?)
- FFDSHOW: 3370, not recommended version (V3326?)
Then it sounds like you need to use the recommended versions of those three programs. The alternates listed above appear to be what is recommended, at least for the latest version of BDRB. http://forum.doom9.org/showthread.php?t=143716
And saltyjd1, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Try to choose a subject that describes your topic.Thanks,Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudzLast edited by redwudz; 6th May 2010 at 22:02.
Thanks for the reply. I was going by the versions recommended in the actual guide. I had just done a couple of other conversions with no problems, that's why I don't quite understand why this one didn't work. I'll have to try and set up a different computer with those versions and see what happens.
I'll do better in the future with my topic titles... -
- Windows Version: 6.1 [7601]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3133, Ok
- WIN7 preferred AVC CODEC: Not Set correctly
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set incorrectly: [0]
- BD Rebuilder v0.37.0.6, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Why don't you need special "accurate" ripping programs to copy DVDs?
By sldvd in forum Newbie / General discussionsReplies: 6Last Post: 15th Aug 2010, 05:30 -
(HELP) "VSFilter Wrong File Version"
By dpunkz in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2008, 18:30 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 19:37 -
Out of Memory Errors Re-Coding "WAR" for Backup
By Newminds in forum DVD RippingReplies: 1Last Post: 6th Jan 2008, 12:00 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32
