Hi everyone,
I'm trying to use one of my Philips TVs usb port to watch a movie and need it to be in mpeg2 format. Through trial and error I figured out that mpeg2 (SVCD ffmpeg preset) is usually recognized on my TV. When I try to convert the .avi to mpeg2 on my latest batch of files it immediately says finished and doesn't convert.
Here the info output.... Any ideas? Thanks in advance,
Phillyman
BTW: It has worked in the past with other files but I played with the settings so it was just plain dumb luck....
/bin/sh: -c: line 0: syntax error near unexpected token `('
/bin/sh: -c: line 0: `printf "Encoding started on " && date && /Applications/Converters/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/movtoy4m -w 720 -h 576 -F 25:1 -a 4:3 /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi | /Applications/Converters/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/ffmpeg2 -f yuv4mpegpipe -i - -y -threads 2 -aspect 4:3 -f rawvideo -vcodec mpeg2video -b 3746 -s 720x576 -r pal -g 12 -me epzs -qmin 2 -qmax 20 -scan_offset -minrate 3746 -maxrate 3746 -bufsize 224 -an -benchmark /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mpv && /Applications/Converters/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/ffmpeg -i /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi -y -vn -f mp2 -acodec mp2 -ab 224 -ar 44100 -ac 2 -map 0.1:0.0 /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mp2 && /Applications/Converters/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/mplex -V -S 780 -f 5 -O 0 -b 230 -r 7716 -v 0 -o /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff-%d.mpg /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mpv /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mp2 && rm /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mpv && rm /Users/xxx/Desktop/Laurel\ \&\ Hardy\ -\ Another\ Fine\ Mess\(Colour\).avi.ff.mp2 && /Applications/Converters/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/au.sh /Users/xxx/Desktop/Laurel & Hardy - Another Fine Mess(Colour).avi.ff && printf "Encoding completed on " && date && printf "\a"
Try removing the parentheses from your filename.
Donadagohvi (Cherokee for "Until we meet again") -
There are other ways to encode. You don't have to use ffmpeg. Of course if you are running this on a non-Windows machine you really needed to have mentioned that. Another possibility for Windows is to use HCenc. It looks like you're probably running on Linux and I don't really keep up with encoding options for Linux because there aren't many. Looks like your final (Colour) isn't escaped with \ like the earlier ones are.
Good Lord man, with all that code you had to use to get ffmpeg to work, I could have gotten your file started encoding with a 1 line AviSynth script fed into HCenc and then adjusted the bit rate using HCenc GUI. That's a lot easier than having to input that monstrous script above. The reality is that no video or audio work is ever easy in non-Windows environments. I hate Windows, but it's where the tools are. -
Mea culpa... Sorry I'm used to posting at mac forums that I forgot to mention the operating system... I removed the "special" characters and all seems well at the moment...
Thanks for the tip.
Cheers,
Philly -
Glad to help.
AVI to DV fails after one.
By bmccall17 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2009, 12:49 -
best program to repair time in a mpeg
By ziptip in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2008, 06:02 -
avi: alright with mediaplayer, virtualdub fails
By engel in forum Software PlayingReplies: 14Last Post: 11th Aug 2008, 04:59 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49 -
encoding from WMV to .avi usin "decode with QT", audio fails
By fury420 in forum ffmpegX general discussionReplies: 3Last Post: 18th Jun 2007, 01:21
