I am trying to rip my first dvd and seem to get as far as making the files with dvd2avi and then when I try to load up the files with tmpg I get a meesage that my d2v file is unsupported. what can I do to fix this problem. I have tried over and over starting from scracth and always get this message, someone help..
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 9 of 9
are you deleting the vob files b4 you use tmpc. i did this and had the same error restored vobs and it worked ok
Make sure you have the right .d2v file. Smartripper also makes one, but it will not work with TMPGEnc.
I have not deleted any files and am using the right d2v file and it still will not load. do I need certain drivers or plugins to make this work?
ok I looked under tmpg/option/enviroment setting/vfapi plugin and all the boxes have checks by them...but in dvd2avi under help there is no check by the vfapi plugin. Is this what I need and how do I get it?
Copy dvd2avi.vfp and dvd2avi.exe to the same directory. Some people had more luck if all dvd2avi and all TMPG files are copied to the same directory. Dvd2avi.vfp should be part of the dvd2avi package. If not, download dvd2avi 1.76 from http://www.doom9.net
thanks it worked, now anybody want to tell me which is the best method of ripping my dvd's to a vcd?
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 20:20 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
