Hi everyone,
I have this idx/sub file that I made, using AViAddXSubs, and the colors are crappy and I want to change them.
I've tried VobSub configure: Loaded the idx file, checked the 'custom colors' and 'save settings..' changed the colors then OK. Now when I play the video, using VLC, it displays the old colors-the crappy ones.
So what I'm supposed to do?
Thanks !
	Maybe dvdsubedit or subtitlecreator. Last edited by Baldrick; 6th May 2010 at 06:29.
	I specified idx/sub format. Seems like those two don't support this format!
 Thanks for trying to help.
 I think the only thing you can do is convert to .sup using SubToSup. Then you can load the .sup into DVDSubEdit and change the palette. The thing is, if the video encoder you use eventually doesn't support the .ifo that goes with the .sup you end up with the same neon looking color scheme. If you are converting to DVD then after the dvd is complete you can use DVDSubEdit to change the color palette. Sometimes that's the easiest way. Some tools like BDSup2Sub will export the color palette values along with the .ifo and .sup files. After you load into DVDSubEdit you can just import that text file to set the palette instead of doing it manually.
 If the output type isn't DVD then I don't know what to advise.http://milesaheadsoftware.org/
 Fully enabled freeware for Windows PCs.
	Thank you all for the help. Problem has been solved.
 All I had to do is reading well the guide; using AviAddXSubsm I disabled the YUV Colors option and then generated the idx/sub files, and they were just what I wanted.
 Thanks again guys!
	Thanks for posting the solution. Maybe now I can avoid neon colors too.  http://milesaheadsoftware.org/ http://milesaheadsoftware.org/
  Changing colors in film to black and white and again colorful with Vegas 10By siopilos in forum EditingReplies: 12Last Post: 3rd Jun 2011, 13:52
  Resizing is changing the colors on me -Solved!By star099 in forum Video ConversionReplies: 9Last Post: 13th Mar 2011, 20:03
  Vegas changing colors of mts files on import. Not levels.By banditeer in forum EditingReplies: 37Last Post: 10th Oct 2010, 08:28
  How to join the idx/sub languages ripped separatedly into just one idx/sub?By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 09:58
  DVD to sub/idx or .sup to sub/idx - How can I do either?By rock_king_my in forum SubtitleReplies: 4Last Post: 10th Aug 2007, 10:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
