i have a couple BlueRay copies of movies and im trying to play them on my mac, i have the most current version of VLC and i asked a buddy and he says VLC is all i need to play these files...
when i play them, i get perfect Video, but only white noise on one and the other is a very high pitched sound..
thanks.
Do you know what format they're in? I'm guessing maybe the original .m2ts format or maybe AVCHD. I would use MediaInfo on a PC to find out, not sure what to use for a Mac.
If there is more than one audio track with the files, try switching it to AC3 in VLCs audio menu, as I'm not sure VLC can decode DTS audio.
And for more Mac specific questions, we have a Mac Forum.
And welcome to our forums.
If you have a couple of BluRay movies... I'm assuming they're in .mkv format correct?
If so, I understand your issue. I too had problems originally trying to play those files on my mac, but VLC seems to not work as well as is does for Windows.
So what I would recommend for you is to download the DIVX codecs (both audio and video) which will enable the QuickTime player itself to play those files (this works for me at leasst)
Here's the link: http://www.divx.com/en/software/mac (just copy and paste it into whatever internet browser you use and download and install all of the components EXCEPT the Divx Player... or else it will constantly try to play all .mkv files using that instead of QuickTime)
**Also, it may help to take a look at installing Perian for QuickTime as well -->this will allow QuickTime itself to play a multitude of different audio/video files**
GL!Last edited by Spdngblt56; 8th May 2010 at 17:11.
Ripbot and keeping dts-hd track issue
By cburbs in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2012, 15:21 -
DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problem
By SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 04:41 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
DTS Sync Issue
By cg1200 in forum Video ConversionReplies: 28Last Post: 24th Apr 2010, 19:53 -
Issue with TSMuxer and DTS audio
By ma2kp in forum Video ConversionReplies: 2Last Post: 25th Oct 2008, 13:16
