On our boat we have a video camera installed so we can record events as they happen. The camera is a simple bullet type camera, attached to a waterproof unit, inside of which a CompactFlash card sits.
The camera writes a .mpg file of around 1.5gb before resetting normally. Each file is sequentially named film1, film2, film3 etc.
However I got the card out the unit the other day and tried to view the film with no luck. I noticed that instead of one file for each 'film' there were two.
FILM4.MPG (2kb)
FILM5.MPA (200mb)
The timestamp for each file was the same or a second difference.
We thought we had 6 recordings on the card, but we ended up with 12 files.
When i tried to play the film, windows media gave me an error about a missing codec, which it had not done before.
From my limited research it seems .mpa format is audio? From what I presume it appears that the audio has been captured and saved as a seperate format and the video has not been captured. Particularly not with such a small file size.
Im a bit stumped what to do, can anyone recommend or suggest what might be the cause of the problem? If the camera is not working, why would it suddenly start recording two formats?
suggestions?
cheers
Paul
				Results 1 to 10 of 10
	As for the malfunctioning unit, inquire where you bought it. It is an unusual system.
 To evaluate the files, open them in mediainfo (free software) and post the results. Then we can recommend a player.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Thanks for the quick reply.
 I will try that software later and see what it says. Im not too bothered about being able to play the files with a different player, as our editing software is the only player we need to play the files, im more concerned as to why its suddenly changed formats.
 As for the system we dont know who the manufacturer is, the camera was fitted to the boat by HQ and they have been unable to tell us so far what they think the problem might be.
 Its weird that for a recording it used to produce one mpg file of about 1.5gb and now for a recording it spits out two formats mpa and mpg, with the mpg file only being 2kb. I guess that means its not making any video recording
 I was hoping someone had had a similar problem and maybe found a fix. I will however still evaluate the files with the software.
 Many thanks
 Paul
	I doubt the camera is producing anything but an analog video feed. The problem is in the unit that digitizes the video. Probably it needs a firmware reset. Hard to tell without any model numbers. Recommends: Kiva.org - Loans that change lives.
	I will try and get you a picture of the camera 'box'. Its a black waterproof box and inside it has a card reader and circuit board, thats about it!!
 cheers
	Here is the output from the software for the 10 files. Like I said earlier the system seems to have created two files for each film. They are paired as follows
 FILM0068.MPG - FILM0069.MPA
 70 - 71
 73 - 74
 75 - 76
 77 - 78
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0068.MPG
 Format : MPEG Audio
 File size : 2.00 KiB
 Duration : 64ms
 Overall bit rate : 256 Kbps
 Audio
 Format : MPEG Audio
 Format version : Version 1
 Format profile : Layer 2
 Duration : 64ms
 Bit rate mode : Constant
 Bit rate : 256 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Stream size : 2.00 KiB (100%)
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0069.MPA
 Format : MPEG Audio
 File size : 128 KiB
 Duration : 4s 96ms
 Audio
 Format : MPEG Audio
 Duration : 4s 96ms
 Bit rate : 256 Kbps
 Stream size : 128 KiB (100%)
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0070.MPG
 Format : MPEG Audio
 Duration : 64ms
 Audio
 Format : MPEG Audio
 Duration : 64ms
 Bit rate : 256 Kbps
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0071.MPA
 Format : MPEG Audio
 File size : 128 KiB
 Duration : 4s 96ms
 Audio
 Format : MPEG Audio
 Duration : 4s 96ms
 Bit rate : 256 Kbps
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0073.MPG
 Format : MPEG Audio
 Duration : 64ms
 Audio
 Format : MPEG Audio
 Duration : 64ms
 Bit rate : 256 Kbps
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0074.MPA
 Format : MPEG Audio
 File size : 208 MiB
 Duration : 1h 53mn
 Audio
 Format : MPEG Audio
 Duration : 1h 53mn
 Bit rate : 256 Kbps
 Stream size : 208 MiB (100%)
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0075.MPG
 Format : MPEG Audio
 Duration : 64ms
 Audio
 Format : MPEG Audio
 Duration : 64ms
 Bit rate : 256 Kbps
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0076.MPA
 Format : MPEG Audio
 File size : 239 MiB
 Duration : 2h 10mn
 Audio
 Format : MPEG Audio
 Duration : 2h 10mn
 Bit rate : 256 Kbps
 Stream size : 239 MiB (100%)
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0077.MPG
 Format : MPEG Audio
 Duration : 64ms
 Audio
 Format : MPEG Audio
 Duration : 64ms
 Bit rate : 256 Kbps
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0078.MPA
 Format : MPEG Audio
 File size : 53.6 MiB
 Duration : 29mn 15s
 Audio
 Format : MPEG Audio
 Duration : 29mn 15s
 Bit rate : 256 Kbps
 Stream size : 53.6 MiB (100%)
	For completeness, here is an older file whic is working fine
 General
 Complete name : C:\Documents and Settings\Paul\My Documents\My Videos\FILM\FILM0062.MPG
 Format : MPEG-PS
 File size : 5.29 MiB
 Duration : 5s 160ms
 Overall bit rate : 8 592 Kbps
 Writing library : PIC Heade
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : Main@Main
 Format settings, BVOP : Yes
 Format settings, Matrix : Default
 Format_Settings_GOP : M=3, N=13
 Duration : 5s 160ms
 Bit rate mode : Variable
 Bit rate : 8 165 Kbps
 Nominal bit rate : 9 500 Kbps
 Width : 720 pixels
 Height : 576 pixels
 Display aspect ratio : 4:3
 Frame rate : 25.000 fps
 Standard : PAL
 Resolution : 8 bits
 Colorimetry : 4:2:0
 Scan type : Interlaced
 Scan order : Top Field First
 Bits/(Pixel*Frame) : 0.788
 Stream size : 5.02 MiB (95%)
 Audio
 Format : MPEG Audio
 Duration : 5s 136ms
 Bit rate : 256 Kbps
 Stream size : 161 KiB (3%)
  deleteBy deuce8pro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Jul 2010, 14:50
  HD Camera, Formats, and Youtube Plus Video EditingBy outback in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 11:39
  SD Video Camera Vs. HD Movie Mode on Digital Still Camera.By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57
  best HD editor for producing DVDBy mtrax in forum EditingReplies: 14Last Post: 12th Aug 2009, 04:59
  Somebody reconize? What barnd & type camera in this picture.By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Aug 2008, 04:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
