ok guys Im doing some SVCD and then I try to convert them to VCD so that my Standalone can play them..(I downloaded a sample of Lord of the Rings SVCD and convert it with Tmpgenc and it works fine) ok now I tried to make some SVDS on my own but when converting them to VCD my Standalone wont play them correct i.e freezing picture "stutter"....???? am I doing something wrong??? I quess so but what??
hi,
you have actually converted them to mpeg1, your not just trying to burn the svcd mpeg as vcd are you?
best way is to rename your svcd mpeg the extension .VOB and load it into flask.
Use the avisynth plug-in to serve to tmpeg, or better still for VCD just use the panasonic plug-in in flask as /i think/ it does better mpeg1 than tmpeg.
If you've done the above and the mpeg IS a compliant vcd mpeg (not mpeg1 system) then what did you use to burn the disc? What media? does your player read CDR?
I ask because if you've done all the mpegging correctly and the picture etc is stalling and you get green mpeg blocks, then that's signs of the disc struggling to read. -
no im trying to put a header on my cds to "fool" my standalone so it plays SVCDs...it worked well with lord of the rings but with my selfmade SVCDs it just wont play...it has something to do with the bitrate I guess..but im not sure
you're tring to make a non compliant disc.Originally Posted by Akhenaton
the higher the bit rate the faster the disc must spin.
the bitrate IS possibley too high.
why don't you just stick the mpeg back through flask and convert to VCD, or if your player does them xVCD. I'm told a xVCD with a bit rate of 1200KbPs looks a LOT better than standard VCD. -
well thanx for your help
I found the solution man it was sooooo easy ;)
I just had to do a simple-multiplex and then burn this sucker as non compliant with Nero and tada it works just great(for me at least)
I just have to spend more time with this programs and someday Im the one replying to some posts LOL
thanx
Anyone want a pirated copy of XP or W7 ? LOL!!!
By Noahtuck in forum Off topicReplies: 13Last Post: 28th Jan 2011, 02:34 -
Screen Melting .lol
By SaVeD in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2010, 15:59 -
Just tell me waht to buy please! LOL
By jboysvideo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2009, 21:01 -
This killed me!!!!! Everyone need's one of these!!! LOL!!!
By Noahtuck in forum Off topicReplies: 6Last Post: 7th Aug 2009, 22:18 -
Front page went loopy ?? LOL!!
By Noahtuck in forum FeedbackReplies: 9Last Post: 11th Sep 2007, 15:00
