I just completed an exhaustive project in Premiere Pro. Basically I took two different edits of a movie and spliced them together to make one long extended edition.
I knew in advance that I had a problem: One of the MPEG2 sources was 23.976 progressive, and the other was a standard 29.97, with whatever processes were involved therein; I believe it was a DVD transfer of a VHS tape, so perhaps "pulldown" would be too generous.
The resulting video is, frankly, too juddery to watch.
Now what I have in mind is to take that 29.97 source and convert it into proper 23.976 (it was originally a film, just like my 23.976 source). Then I could do the editing in the 24fps world and the result ought to be quite acceptable. Trouble is I don't know where to begin.
Obviously I have one option to me: Render the whole thing as 480p at 59.94fps raw, and manually cut out every nth frame. I believe such an approach would sacrifice both my sanity and some 100 hours of my life. There has to be a better way.
Thanks in advance.
check out dgindex. That has a pulldown option I believe. I know it works the other way 23.976 to 29.97 - I just did it this past weekend on a bluray to dvd conversion that was interrupted prior to final muxing. I have to imagine it goes the other way too.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
A VHS source would have hard pulldown so you need to inverse telecine. Use DgIndex to build an index file (honor pulldown flags mode) then open the video with AviSynth and use TFM() and TDecimate():
Mpeg2Source("filename.d2v")
TFM()
TDecimate()
Post a short sample with motion. DgIndex can trim out a small section and demux it.
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:30 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:29 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 22:31
