Hello folks.
I recently managed to transcode from DIVX to an MPEG-2 Transport Stream carrying MPEG-4/H.264 video with AAC (FAAC) audio in two steps, using avidemux for transcoding and VLC for encapsulation(avidemux just won't pack h.264 in an MPEG2 TS ).
The problem now is that I need it with constant bit rate, with dummy packets making up for the variable bit rate in the h.264 encoding. My TS has variable bit rate, which is useless for my application. Thus, this issue is not the same as that other thread asking for tips on AVI to TS.
Any tips on how to obtain constant bit rate on either VLC or avidemux? I also noticed that only the windows version of VLC allows me to copy the original video and audio while only changing the encapsulation.
The application is DTV broadcasting in a test environment, my multiplexer only accepts CBR input in MPEG-2 TS containing MPEG-4 h.264 video/ MPEG-4 AAC audio.
I tried TSmuxer with mux CBR at 8000Kbps and VBV buffer size between 200 and 1000ms
This is the error I got (itīs too long to be posted on it entirety because there are too many buffer overflows).:
VBV buffer overflow at position 1.46986 sec
VBV buffer overflow at position 287.42 sec
Too many errors! tsMuxeR is terminated.
So I tried to buffer for shorter periods, but still the buffer keeps overflowing. I figure ther is something else to it.
Stream out with cbr
By brankoilke in forum Video Streaming DownloadingReplies: 0Last Post: 5th Sep 2011, 11:23 -
MP4 VFR to AVI CBR conversion...
By Atakanbasturk in forum Video ConversionReplies: 0Last Post: 16th Jul 2010, 12:20 -
How to convert .CBR video file to WMV or AVI?
By microline2009 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jan 2009, 02:05 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 18:48 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 14:28
