I used to use a python app which was running at awesome.jakewharton.com but it has been offline for weeks. I tried setting it up myself from http://github.com/JakeWharton/is_awesome but without any luck. Is there any other place or app which I can use to check DXVA compliance?
Thanks jagabo. I only just searched for "dxva compliant/compliance" without founding anything.
Ah, I probably wasn't clear enough. I meant checking if a video file is DXVA compliant, not the hardware. I know there's just a 10 or so stuff you need to check in MediaInfo, but that DXVA compliance page was nice. You pasted the info from MediaInfo and it check up the DXVA complaince and showed also the recommended values.
Though I guess I could just check the python code and check DXVA complaince "manually".
DXVA video
By thezanny in forum Video ConversionReplies: 5Last Post: 9th Dec 2011, 19:53 -
Rip Using DXVA ?
By swordfish666 in forum Video ConversionReplies: 5Last Post: 19th Sep 2010, 01:05 -
Anybody know anything about VC-1 (in WMV) acceleration using DXVA ?
By davexnet in forum Software PlayingReplies: 0Last Post: 10th May 2010, 18:18 -
DXVA with VC-1 files
By Grizz111 in forum Software PlayingReplies: 1Last Post: 8th Feb 2010, 14:57 -
Is there a soft that really scan a video stream to check L4.1 compliance ?
By vega1970 in forum Video ConversionReplies: 2Last Post: 9th Feb 2009, 21:45
