Here is a screenshot :
Can it please be removed from VOB2MPG Pro ?
false positive
upload it to www.virustotal.com to confirm. They will scan it with 40 different scanners. I bet avira is the only one that reports this.
edit
I should say as long as the file was downloaded from the authors site then it is clean. If you downloaded this elsewhere then you probably do have a virus.Last edited by freebird73717; 5th May 2010 at 09:10. Reason: added more info
Donadagohvi (Cherokee for "Until we meet again") -
Here is the analysis:
http://www.virustotal.com/analisis/7611c0aadb74edfd1af9042f0182b078ebf1e15d6e1c78624a6...ac4-1273573089
Indeed avira IS the only one reporting the false positive. Perhaps the tmpvob2mpg.exe and vob2mpg.exe files can be added to its exclusion list within the software (if it has one - i have never heard of it to be honest).SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
After submitting the avira they have acknowledged the false positive@
http://analysis.avira.com/samples/details.php?uniqueid=VwO9H5xY3KwKdTd5WqZI45Jg1CL8QGR...identid=510443SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I use a pain in the ass anti-virus, Kaspersky (but I love it cause I haven't gotten a virus for years using it). It scrutinizes everyhthing. I scanned VOB2MPG Pro it and it has no damn virus, trojan, worm, bla bla bla.
The developer of VOB2MPG is honest and straight up. He's good people.
Virus total will report Windows 7 as a virus, if you could upload it.Last edited by Joey9; 21st May 2010 at 11:46. Reason: scrutinize
Trojan Virus=C:\FOUND.011\file0000.chk. - Problem Solved
By blinky88 in forum ComputerReplies: 10Last Post: 6th Feb 2013, 23:17 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Virus found in AnyDVD
By pepegot1 in forum ComputerReplies: 9Last Post: 10th Sep 2009, 11:59 -
Virus found - False positive?
By misterstormcrow in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2009, 14:21 -
found very high quality free web site to check if a file has a virus
By jimdagys in forum ComputerReplies: 13Last Post: 26th Aug 2008, 10:48
