I recently installed DivX 8 and i really liked that it can make thumbnail previews for mkv videos (Most of the time). But if it can't generate a preview for an MKV clip, it brings the PC to its knees by gradually eating up all the RAM, the RAM usage goes from 20% to all the way above 98% and after about 5 minutes or so it goes back to normal but the PC still remains extremely slow and the only possible solution to get back to normal is a full reboot. This happens again and again when i open the folder which contains that particular MKV and i really don't want to disable the complete thumbnailing of videos. As a matter of fact, i installed DivX totally for mkv indexing. This only happens when divx can't able to create a preview for an MKV. I think out of 80+ MKV's on my hdd, only 3 mkvs are making this problem and those MKV's are not corrupt at all. I can play them fine using MPCHC or VLC and seeking, subtitle's everything works.
Here is the mediainfo detail of one of those videos.
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 6 900 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.312
Stream size : 7.00 GiB (88%)
Title : x264 MP4 Videostream
Writing library : x264 core 54 svn-594
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=6900 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=1 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
It looks like there's a bug in Divx8 if it's eating up all memory while attempting to build a thumbnail. You might try remuxing the MKV files and see if that will get around the problem.
Try FreeRAM XP Pro
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
DVDlab pro eating some legends
By bebado22 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 16:54 -
ReSize MKV - HandBrake hanging on new system (process stopped)
By Raycaster in forum Blu-ray RippingReplies: 1Last Post: 10th Sep 2010, 06:42 -
Is there a one-step freeware program for mkv to wmv that works 100%?
By yoda313 in forum Video ConversionReplies: 2Last Post: 14th Mar 2009, 22:30 -
Any other options for mkv to vob? Mkv2vob doesn't work 100% of the time
By AndyD in forum Video ConversionReplies: 6Last Post: 12th Mar 2008, 19:13
