(disclaimer: this thread not approved yet by jman98; read at your own risk)
I think it's only a configuration setting (cache maybe?), and I'm not knowing which one or how - need to know what the RANGES are first...
But the problem is that all my videos look better in 32bit XP playing in Media Player Classic, than playing in MPlayer Movie Player, with x64 Hardy. CPU is 3x core, 2G memsticks, so hardware isn't the problem I don't think.
What configuration settings should I start with?
Have you been able to rule out any configuration changes that have no effect?
Frequency scaling - this is a hardware configuration?
My mobo (new build) does NOT recognize my CPU model; it IS compatible, and a BIOS flash I think is in order. BUT, wouldn't that effect BOTH operating systems equally? -
The MPlayer playback system is completely different from MPC-HC's so the reason could lie anywhere. It's probably not got to do with your BIOS issue, though.
You can post a sample video here, grab a frame under your MPlayer, and ask someone else to grab the same frame with MPC-HC (stating the settings/renderer/decoder involved). Then we can compare the two and look for differences.
HuffyUV Vid Has Crazy Colours in VirtualDub and Vegas But Plays OK in MPC ?
By blewyn in forum Video ConversionReplies: 1Last Post: 5th Apr 2012, 11:31 -
What to do to play AVI TSCC in MPC-HC (Windows 7) ?
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2011, 18:25 -
FFMPEG - Windows vs Linux ?
By Klagar in forum Video ConversionReplies: 3Last Post: 14th Oct 2010, 12:32 -
Windows and Linux
By FulciLives in forum LinuxReplies: 1Last Post: 30th Jul 2008, 09:59 -
Worse video quality on Linux than Windows with mencoder
By chiun in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 04:29
