i am new to this i want to put a movie on to disk as vcd but tmpgenc needs DivX 3.11 i got that that on my pc now i need DivX 4 and i can not find can some one tell me were i can get it the DivX site does not have it online or can i use the new DivX 5 codec
many thank
i am NEW to this sort of think
Results 1 to 13 of 13
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
i found that site but the links r missing every time i go to download the file is missing is they any problems with DivX 5 codec i heard it is new
thanks i got it now i can use TMPGEnc yyyyyyyyyyeeeeeeeeeaaaaaaaaahhhhh did u know i am only 13
dude i am geting pissed of now i have the 2 codecs but it staying that my file (avi) is unsurported or can not open what can i do i tryed the other codecs i done every thing in the guide
Problems:
If TMPGEnc gives you an error message when opening AVI, DivX,ASF,SMR,NAV be sure that you have installed the DivX Codec(both DivX 3.11 and 4 codecs) and also try with the Nimo Codec Pack. If that does not work try to use the old TMPGenc 12a. If that does not either work try to change the settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow and increase the priority to 1 and try open the video.
and it will not load what other programs do u think will work and r easy to use -
Hi Try first install the Nimo codec pack
http://users.chartertn.net/bpearson/
If it does'nt open the avi after installed Nimo. You maybe got
a' broken avi file. Not a complete movie. Download DivXfix
( I think you find it here in Tools page). And run.
Or Try to open it in Virtual dub...and then Openfile information,
checking type of codecs used....
Good Luck -
dude it is cool now the program is working thanks man when i cum to put it on to a cd do u think a 89mins flim fit if no what the best way to make it shorter like i heard that if u split the audio and video and make the audio mp3 and then put it back to gether in tmpgenc would make it smaller is this true i would like to know for futher
many thanks
paul the newbie AGE 19 -
Sorry..But I'm no expert......
I mostly makeVCD's. No
avi to CD's. Are you going to save the film on a' cd or..?
Then you could use AviChop....to cut the avi file.
Or just convert the avi (DivX) to Mpg.......Make a'vcd or svcd and
play it on a standalone Dvd player. Use VCD Cutter or TEMPGEnc
to split Mpg file.
Good Luck again
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 07:21 -
Advice on which codec pack to download.
By prankstare in forum Newbie / General discussionsReplies: 26Last Post: 8th Sep 2009, 08:13 -
which codec to download to play DVD on wmp 10 ?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2007, 00:28 -
Where is the Divx test DVD (for download)???
By Hank Kinsley in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 18:56 -
Need to download a YUY/DIB Codec
By vegasarian in forum Newbie / General discussionsReplies: 9Last Post: 23rd May 2007, 10:02
