Is there a way to convert a 4:3 letterboxed .avi file to an anamorphic mpeg-2 file? I've been making some dvd's and I've converted the letterboxed avi's to mpeg-2's and the resulting dvd's appear on my tv as letterboxed. All well and fine, but when I play the dvd on my pc with the hi-def widescreen display, the result is letter-& pillar-boxed.
I'd like the picture to fill my widescreen pc display and appear letterboxed on my tv.
I use tmpgenc 2.5 for video conversion, but if there's a way, I'd be willing to get other software.
Thanks!
"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
The 10th Doctor from "Blink" -
Will that make the file truly anamorphic? If so, how do do I crop the picture?
You will need to crop off the top and bottom of your avi files till you get an aspect ratio of 16:9. If your avi's were 640x480 you would crop 60 lines from the top and 60 lines from the bottom. This will give 640x360 which is a ratio of 16:9. When you import these into your DVD authoring program it should recognize them as 16:9 and create anamorphic 16:9 DVD's.
What DVD authoring program do you use? There might be a setting to crop the video before encoding to mpeg-2. -
I do that using Avisynth and HCEnc.
For instance, some TV shows made in widescreen that on DVD were letterboxed into 4:3 frames, I cropped the hard letterboxing off and made them anamorphic widescreen. Then used HCEnc to make MPEG from these:
I use AvsP to finetune the cropping, it has a crop editor.Code:AVISource("B3.avi") # 720x576 letterboxed Crop(10,88, -16, -86) LanczosResize(720, 576) -
Thanks for your help.
And Jagabo....nobody's forcing you to answer. If you got nothing constructive to say...Bug off!"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
Convert 4:3 letterboxed(16:9 picture inside a 4:3 canvas)to 16:9 Anamorphic
By SatStorm in forum User guidesReplies: 30Last Post: 13th Dec 2010, 10:18 -
Letterboxed 4:3 to Anamorphic 16:9 with AviSynth
By Koppel in forum Video ConversionReplies: 13Last Post: 13th Aug 2010, 03:49 -
Converting 16x9 video to 4x3 letterboxed in Sorenson Squeeze
By pjbarbour in forum Video ConversionReplies: 0Last Post: 10th Mar 2010, 10:49 -
How do I get my 16x9 anamorphic clip to play letterboxed on a 4:3 screen?
By buddyreid in forum Newbie / General discussionsReplies: 6Last Post: 26th Sep 2009, 03:14 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
