I am going to rip a bunch of dvds to either xvid or x264. I know x264 is better quality but xvid is so much more compatible and faster to encode. My question is if i convert a dvd to xvid at 2500-3000 kbs will it look the same in quality as if i converted the same dvd to x264 at 2500-3000 kbs? Thank you
short answer : noMy question is if i convert a dvd to xvid at 2500-3000 kbs will it look the same in quality as if i converted the same dvd to x264 at 2500-3000 kbs?
But it will depend on the specific source, and encoding settings used. If it's an action movie, with lots of motion, explosions etc... the xvid version will look significantly worse, even at 2.5-3Mb/s . If it's a static movie with low noise, well lit, little motion (maybe an interview or something) , there might be very small perceptible differences
FYI , x264 is highly configurable. You don't have to use super slow , higher quality settings. For example, on an i7 , x264 is faster to encode and better quality than xvid with --preset fast or faster , because it scales so much better than xvid with multiple cores
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 15:37 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 20:40 -
Source bitrates and x264 crf settings?
By orangeboy70 in forum Newbie / General discussionsReplies: 10Last Post: 2nd May 2011, 22:15 -
Any Disc Player that handles high bitrates from HD conversion?
By EAO in forum Newbie / General discussionsReplies: 7Last Post: 27th Feb 2008, 15:38 -
Bitrates really high in H.264 files
By limeyx in forum ffmpegX general discussionReplies: 3Last Post: 16th Dec 2007, 19:55
