  1. Hi,
    I'm trying to find the best way to archive my DV videos and convert them into manageable size.
    My original interlaced video plays really well on my Windows 7 media player - it's automatically de-interlaced and plays full resolution and looks really smooth. However, when I convert to H.264 with SUPER, the video plays with the noticeable field difference. SUPER automatically de-interlaces (I think) but I actually want to keep the interlace because it comes out much much smoother when I play it (I've attached links to screenshots below).
    Anyway, I'd like to do one of two things:
    • Either convert to H.264 and keep interlaced so playback is as smooth as original DV, or
    • find something that de-interlaces as smooth as the playback of the original DV video appears to be.
    Help on accomplishing either of these is greatly appreciated!
    Thanks!!!
    The DV capture:
    http://img30.imageshack.us/img30/720/vidtestdvint.jpg
    The H.264 capture:
    http://img266.imageshack.us/img266/352/vidtesth264int.jpg
    DV video MediaInfo output:
    General
    Complete name : C:\temp\Tape16 22.avi
    Format : AVI
    File size : 197 MiB
    Duration : 54s 482ms
    Overall bit rate : 30.4 Mbps
    Recorded date : 2003-10-18 15:46:45
    Writing library : Tdattc_O
    Video
    Format : Digital Video
    Codec ID : dvsd
    Codec ID/Hint : Sony
    Duration : 54s 480ms
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Original display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Bits/(Pixel*Frame) : 2.357
    Stream size : 187 MiB (95%)
    Encoding settings : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Unsigned
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 9.98 MiB (5%)
    Interleave, duration : 991 ms (24.76 video frames)
    H.264 video MediaInfo output:
    General
    Complete name : C:\Users\amir\Videos\DV\Tape16 22 - SUPER 32000 deint.AVI
    Format : AVI
    File size : 21.6 MiB
    Duration : 54s 396ms
    Overall bit rate : 3 332 Kbps
    Director : created.with.SUPER(C).v2010.bld.37
    Writing application : SUPER(C) - by eRightSoft
    Video
    Format : AVC
    Format profile : High@L1.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : AVC1
    Duration : 54s 120ms
    Bit rate : 3 242 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.313
    Stream size : 20.9 MiB (97%)
    Writing library : SUPER(C) by eRightSoft
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Bit rate : 96.0 Kbps
    Sampling rate : 32.0 KHz
    Stream size : 637 KiB (3%)
    Alignment : Aligned on interleaves
    Interleave, duration : 36 ms (0.90 video frame)
    Interleave, preload duration : 504 ms
  2. 1) "archive" implies original quality, so I would keep the originals for future projects. Any re-encoding / lossy compression will cause quality loss. And you want to keep it interlaced for projects such as making DVD. Deinterlacing will irreversibly damage it.
    HDD's are very affordable these days. You can get 2TB HDD for ~$130-140 CDN
    2) super is probably single rate deinterlacing to 25p; you could use other programs to "bob" deinterlace or convert to 50p (since 50i is 50 FIELDS per second), and keep the smoothness/temporal resolution. avisynth offers multiple high quality deinterlacers (better than the ones you get with realtime playback) , but it can be a bit difficult to learn at first
  3. Originally Posted by poisondeathray View Post
    Thanks for the reply! Sorry for my late one, I've been trying avisynth for the past couple of days w/o much luck. Can you maybe point me to a newbie tutorial on how exactly do I use it? I've downloaded a de-interlacer plugin but I don't know how to automatically create scripts and run them on a group of files (I have 100's of files, can't go through manually de-interlacing them).
  4. To effectively use Avisynth you should get AvsPmod, which shows you the output of your script, frame by frame.
    Anyway, to deinterlace with decent quality, get the Yadifmod and NNEDI2 packages, install them, then use one of these scripts (taken from an old post by PDR):
    single rate (final output 25fps):
    AVISource("video.avi")
    interp=NNEDI2(field=0)
    Yadifmod(order=0, field=-1, mode=0, edeint=interp)
    double rate (final output 50fps and a lot bigger filesize-wise):
    interp=NNEDI2(field=2)
    Yadifmod(order=0, field=-1, mode=1, edeint=interp)
    Create a text file with the extension .AVS and paste the script you want into it, save it, and use that AVS file as an input to a good encoding program (not SUPER) that takes AVS as input. Try StaxRip, I think it does.
    If you get AvsPmod, you can open the AVS file and see how the deinterlaced frames look.
  5. Thanks creamyhorror! Those filter settings work great and provide output that's actually even better than Windows Media Player (at least the few clips that I've tested).
    I'm actually using VirtualDub for the encoding, and found Avisynth Batch Scripter (very simple program) to auto-generate the hundreds of scripts I need.
    Now I just have to figure out what to do with the DV tapes to preserve them for the next 10-20 years...
    Thanks again!!
    Jun 2010
    Murcia
    Hi! Im having the same problem. Im converting my too much big DV tapes into MKV H264/AVC with SUPER, but Im having this problem. The result video have a lot of horizontal lines (¿interlaced? ¿deinterlaced?)
    There is some way to avoid this with SUPER (not with AVsynth please)?
    I could import the video from the tape in two formats, DV Type I and DV Type II. Would some of these types solve this problem with super?
    Its MKV H264/AVC the best codec to save my home tapes? Would you recomend other codec?
    I will preserve my tapes also, the files are to have it more accesible.
    PD: In SUPER, when I use other formats different from MKV, there is in OTHER OPTIONS, one that says: Deinterlaced to progressive... etc, but these options are disabled when use MKV, Could this be the solution?
