My boyfriend is using 2 Toshiba laptops to connect to a switcher which will be connected to projectors in order to show some video for a convention. The Toshiba specs are below (both are the same). The problem is that the laptop does not have an S-cable port, which he is familiar with from a previous convention. It does have the following ports built in:Toshiba laptop specs:
- Video
RGB (monitor) output port
REGZA LINK™ (HDMI-CEC)
1080p support- Audio
S/P DIF output port (shared with headphone port)
Microphone input port
Headphone output port- Data
i.LINK™ IEEE-1394
USB v2.0 – 4 ports with sleep and charge12
3 x USB v2.0
1 x eSATA/USB combo port
RJ-45 LAN port
RJ-11 modem port
Toshiba Qosmio X305-Q701
Intel® Core™ 2 Duo Processor P7350
2.0GHz, 3MB L2 Cache, 1066MHz FSB
PC3-8500 DDR3 1066MHz SDRAM 4G
200G SATA HDD
Nvidia GeForce® 9700M GTS, 512MB GDDR3
windows 7 ultimate 64-bit
How can he connect the projectors to the laptops with the above configuration without the S-cable port? Any help would be greatly appreciated! Thanks in advance!
The majority of projectors will have VGA (i.e analog monitor) inputs . Check to see if it does , or look at the spec sheet
A projector that has ONLY s-video would be exceedingly rare. I doubt it exists.
Otherwise you can get a converter cable (VGA=>S-video) -
Your "RGB Monitor output port" is a VGA port, and is available on 90% of laptops. If the projector has the same type of jack, you might could get a KVM switch (not sure if that's the type of switch you were referring to). You don't say if the Qosmio (?) has HDMI, but if it did, and your projector did too, it might be another (probably better quality)option. The VGA->VGA option would also be much better than S-Video in the chain.
edit: You didn't say if you wanted the "swticher" to be like a live video switcher/mixer (with overlays, PIP, etc) or just an A/B switch?...Last edited by Cornucopia; 4th May 2010 at 22:17. Reason: Addendum
Electrical arc when plugging a VGA cable to a video projector into a laptop
By ggarland in forum Newbie / General discussionsReplies: 8Last Post: 20th Mar 2011, 21:17 -
HD video camera hookup to digital projector
By MTguy in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2011, 20:08 -
Combining Flash projector .exe presentation with DVD quality video
By alexmc in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2010, 12:44 -
Connecting laptop VGA to TV S-video
By tezarin in forum Newbie / General discussionsReplies: 7Last Post: 2nd Apr 2009, 17:09 -
Taping a projector slide presentation -- color shift :?:
By shieber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 28th Nov 2008, 15:07
