Hey, I have an .avi with 2 audios (dual) and I wanted to pass it to a dvd-video (to watch it in a regular dvd player), for what I usually use NERO. The thing is that I want to create a menu where you can select the audio. How do I do that?
Thanks!
Thanks, It worked great. I'll later try TAW, when I find a non trial version.
I also wanted to ask something about dvd-video created out of avi files. If we have a 1.4 GB avi file and we use it to create a DVD-video, is there quality lose for the dvd? (considering we want to burn it in a 4,3 DVD) -
Probably. It will vary form AVI to AVI depending on the running time, resolution and bitrate of the source, the encoder used to convert it for DVD, and other factors. There is no absolute yes or No answer. As a general rule though, encoding from one lossy format to another will incur a loss to some degree, and anything else you have to do to it (resizing etc) will increase the loss. Sometimes it will be visible, sometimes it won't. In the case of Xvid/Divx material what it usually does is expose the shortcoming of the original encoding, making macro-blocks and other compression issues that were already there, but perhaps not so visible on your monitor, more obvious - especially when played back on a TV.
Read my blog here.
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
trouble with SVCD2DVD menu selection highlighting
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 15:59 -
slow in menu selection for WMC wireless
By faridgh in forum Media Center PC / MediaCentersReplies: 0Last Post: 26th Apr 2011, 22:09 -
Chapter screens for scene selection menu question?
By ecc in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 15:49 -
Create DVDLab DVD Scene Selection Menu
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 09:22
