I watch television through my PS3, I got fed up constantly changing CD's everytime I wanted to watch a movie so I built a MediaServer.
I wanted to store all my DVD's on the mediaserver especially things like LOST series. Then I can just select play all and sit back and relax.
Here's the problem a lost disc will start with 2 folders Audio_TS and Video_TS, inside are .VOB files.
I've been copying all these .VOB files out deleting the ones which aren't a scene and renaming them as .mpg files so they will play back on the PS3.
Now 90% of them are perfect but there are some wierd things happening.
For example one of the .VOB files played back in japanese on the PC, I renamed it to .MPG and it now plays english on the PC but load it up on the PS3 and it's Japanese.
In Season 3 disk 3 and 4 are both in foreign, on the PC I can select english but on the PS3 I do not have this option.
There are different language problems on other disks but I'm not about to go through them all.
I guess my question is how do I change the default audio?
These .VOB files certainly have English in them but for some strange reason it isn't always the default.
I'd ideally like to remove all other languages and commentary so it had no choice but to always use English.
I don't see any other option other than making your preferred language the ONLY language....and that is done easily by re-authoring the DVD.
How to edit MKV data without remuxing (change default audio, rename lang)
By spycam in forum Newbie / General discussionsReplies: 10Last Post: 28th Jul 2015, 05:54 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
How can I set the default audio stream of a .VOB file?
By knn in forum EditingReplies: 9Last Post: 19th Jan 2009, 20:10 -
How can I change default audio track with DVD Flick?
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Feb 2008, 07:16
