I have a pretty good system running WinXP and a Conexant TV tuner. I've been using Windows Media Center Edition (MCE) to capture TV programming and then converting the DVR-MS to Mpeg and that's been working well for me for 3 years. Recently that changed. MCE is now putting copy protection on some TV programs (American Movie Channel, for example). So I need to find another capture software.
Can anyone recommend a free (or low-cost) software? I have basically two hard requirements (if I can get them):
1. Software will capture programming from my Conexant TV tuner on my WinXP system
2. Software has a SCHEDULER; meaning, I can schedule the recordings in advance and they'll start recording hands-free.
Anyone?
THANKS!
http://www.kiva.org/about -
edDV, thanks for the reply. However, I've already invested in the setup I have and don't really want to put out more $$ for a different setup.
if it is an analog tuner, using rf input might bypass the protection, though quality will not be as good as using component or av connection on the tuner.
Video Capture PCI / USB recommendation?
By harky in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 19:04 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 05:50 -
I Have Nero 7 Ultra but Need Video Capture Device Recommendation
By Classic '57 in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2009, 17:45 -
Video Capture with Mplayer, Mencoder or ffmpeg under Winxp. Is it possible?
By gll99 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 18:00 -
Software recommendation for intermediate video editing ??
By garybeck in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2008, 20:56
