hello friends i got a question
i have been googling for a while and this is my problem:
i want to move the vertical position of a srt subtitle in english a bit lower than usual, cause there is an asian subtitle hardcoded on the movie. i want to lower it down so i can read it clearly.
i try the so called vobsub(the green arrow click settings and override position, it doesnt work at all) and fddshow and i dont know what to do, i use VLC player cause its the only one that plays the mkv without playback problems, so please dont ask me to use windows media player classic cause it doesnt work.
i also want to merge the subtitle to mkv, i know how to use mkvtoolnix and its very easy to strip audio and subtitles, but the thing is, there is no point in merging the subtitle if its not moved vertically a bit.
is there any plugins to mkvtoolnix that deals with subtitles?
or any help appreciated.
In VLC settings have you tried in Subtitle section "force subtitle position"? You should be able to move it down by x number of pixels. Splash Lite player handles .mkv very smoothly but the subtitle support is sparse. .srt sub and I don't think you can move them. It's a shame because it's the only player I've found where I can play .mkv and move the slider however I want without the player going away.
I keep posting on their forum to improve the subtitle support. Maybe they will in v. 1.4http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
subtitle position with aviaddxsubs
By marioval in forum SubtitleReplies: 3Last Post: 27th Feb 2011, 19:15 -
How to move subtitle position in MPC-HC?
By Stealth3si in forum SubtitleReplies: 2Last Post: 14th Feb 2011, 05:46 -
Subtitle Position
By Abas-Avara in forum SubtitleReplies: 9Last Post: 25th Mar 2010, 15:09 -
1080p MKV squished vertically in WMP/ffdshow
By Osirus23 in forum Software PlayingReplies: 4Last Post: 19th Nov 2009, 12:15 -
MKV Merge subtitle error
By zzyzx2 in forum SubtitleReplies: 2Last Post: 1st Jun 2008, 23:44
