I recently acquired a 1280x720p MKV container file with english+french DTS 5.1 sound and subtitles in ENG, FRE, GER that plays in VLC Player just fine on Win7Ultimate x64. All I want is to make an AVCHD disc with ENG sound and subtitle (encoded on video or selectable). I've tried using about 4 or 5 diff tools with no luck this weekend and hoping someone has a solution. Here's what I've tried:
1) TSXMUXER: no mater what I do, the audio is out of sync with video
2) MKVtoVOB: No subtitle show up
3) MKVToolNix (with MKVMerge): I can strip the FRE/GER subtitles and audio out, making the file smaller in MKV, but the train stops there. I guess I can see if there's a way to make an MT2S with subtitle embedded.
4) Ripbot264 (with MKVExtract): I tried to extract the subtitle as SRT, then use Ripbot264 to force the subtitle SRT file back in as selectable AND embedded, but after 4 hrs of encoding, I found out subtitle only applied halfway through the movie....almost perfect, but no go. Maybe the SRT file was not complete, I'll have to check in Notepad later.
BUT, is there an easier tool to merge MKV container files with SRT or even the embedded subtitle in MKV to force and show up? I also try to make ENG audio primary on some MKVs that has foreign audio as primary, but no luck when playing back via streaming with Tversity (even if encoder is set to ALWAYS) or making an AVCHD disc.
Blu Ray to MKV with optioinal multi-language audio/subtitle support
By minerva.thegift in forum User guidesReplies: 10Last Post: 6th Oct 2014, 03:53 -
conversion blu-ray to dvd that select audio/subtitle tracks as requirement
By wisitch in forum Video ConversionReplies: 4Last Post: 25th Nov 2011, 07:04 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
How to strip audio or subtitle tracks off a Blu-Ray Disc
By ppeterr in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jul 2010, 13:45 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28
