HI All, been using svcd2dvd with no problem up until today and get error message. Here is a copy of the log for this:
Any help appreciated!
cheers, David w
Title: 2.5
Version: 2.5.5030.0
Executable: C:\New folder\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2711635
Executable CreationTime: 28/01/2009 15:57:36
Executable LastWriteTime: 03/05/2010 11:53:07
Executable LastAccessTime: 03/05/2010 11:53:07
************************* Operating System *************************
Operating System: Microsoft Windows 7 Home Premium
Service Pack:
Version : 6.1.7600
Windows Directory : C:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 3.99 GB
Free Physical Memory: 1.83 GB
Total Virtual Memory: 7.99 GB
Free Virtual Memory: 5.49 GB
***************************** Computer *****************************
Computer Manufacturer Name: GBT___
Computer Model: NVDAACPI
System Type: x64-based PC
Computer Name: PHENOM
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: Phenom\David
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Phenom(tm) 8400 Triple-Core Processor
Description: AMD64 Family 16 Model 2 Stepping 2
CPU Speed: 2.11GHz
CPU FSB: 200MHz
L2 Cache Size: 512 bytes
12:55:03: Logical CPUs: 3
***************************** Time Zone ****************************
Time Zone: (UTC) Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: ATI Radeon HD 4350
Processor: ATI display adapter (0x954F)
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 512 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 148 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 26.5 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 24.6 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 14.3 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="03/05/2010 12:55:04" Filename="G:\all video\projects\avatar.s2d">
<AssetSet>
<Asset ID="f90b14ac-f25a-48a1-8da2-678a13ded24b" Path="G:\all video\from torrents\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy" Filename="Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy.mkv" />
</AssetSet>
<DVDStructure>
<TitleSet Name="Avatar" PostCmd="" MenuButtonType="0">
<MenuButton X1="106" Y1="109" X2="246" Y2="162" FontFamily="Tahoma" FontSize="28" FontStyle="3">Avatar</MenuButton>
<Title Name="Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy.mkv" AssetID="f90b14ac-f25a-48a1-8da2-678a13ded24b" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-8323328" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="G:\all video\graphics\avatar.bmp" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 20 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files (x86)\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 699 MB
file=G:\\all video\\from torrents\\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy\\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy.mkv
FormatName=matroska
Num_Frames=232618
DurationInSecs=9703
Duration=02:41:42.1
VideoCodec=h264
VideoFFSTNum=0
Width=640
Height=352
Standard=NTSC (Film)
BitRate=0
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x0]
Audio1SampleRate=24000
Audio1Codec=aac
Audio1BitRate=0
Audio1Channels=6
AVI2MPG: 3288kbs Full-D1
Pass 1/1: Processing Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy.mkv
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Using pulldown.
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: libavutil 49.12. 0 / 49.12. 0
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: libavcodec 52. 6. 0 / 52. 6. 0
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: libavformat 52.23. 1 / 52.23. 1
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: libavdevice 52. 1. 0 / 52. 1. 0
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: libswscale 0. 6. 1 / 0. 6. 1
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Input #0, matroska, from 'G:\all video\from torrents\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy.mkv':
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Duration: 02:41:42.14, start: 0.000000, bitrate: N/A
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.0: Video: h264, yuv420p, 640x352, 23.98 tb(r)
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.1(eng): Audio: aac, 24000 Hz, 5.1, s16
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Output #0, dvd, to 'G:\all video\from torrents\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy_S2D.mpg':
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 3288 kb/s, 23.98 tb(c)
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream mapping:
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.0 -> #0.0
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Stream #0.1 -> #0.1
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Press [q] to stop encoding
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: [h264 @ 0x32222e0]Cannot parallelize deblocking type 1, decoding such frames in sequential order
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: [aac @ 0x1330ec0]SBR not implemented. Update your FFmpeg version to the newest one from SVN. If the problem still occurs, it means that your file has a feature which has not been implemented.
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Resampling with input channels greater than 2 unsupported.
[Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy] 12:55:04: Can not resample 6 channels @ 24000 Hz to 6 channels @ 48000 Hz
12:55:06: Done: Processing assets for DVD creation
Authoring DVD Folders
12:55:06: Creating TitleSet # 1
12:55:06: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
12:55:06: -->: DVDFolders creating VTS
12:55:06: -->: VTS 01
12:55:06:
DVD Folders: Processing C:\New folder\dummymenuNTSC.mpg...
12:55:06:
DVD Folders: Processing G:\all video\from torrents\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy\Avatar[2009]DvDRip-x264-AAC[5.1]Eng-MKVGuy_S2D.mpg...
12:55:06:
Closed Thread
Need a speaker system for the TV
By beavereater in forum Off topicReplies: 2Last Post: 7th Sep 2011, 18:18 -
New system
By didikai in forum Newbie / General discussionsReplies: 14Last Post: 21st Jun 2011, 07:36 -
Certain Files Crash the App With a AccessViolationException (RESOLVED)
By sengsational in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Jul 2009, 12:33 -
System.AccessViolationException
By pacit999 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 6th Jan 2009, 06:28 -
System
By Seasonal in forum ComputerReplies: 3Last Post: 26th Jun 2007, 09:54
