I have an AVI file i want to add subtitles to using AVIDEMUX.
I add in subs (.srt )using the move edit drop down menu,and in the "preview section" all is well,and subs are clearly shown on the movie.
But when i save as new avi file,there are no subs,am i doing something wrong?
All help appreciated.
Pensioner.
	Yes, or you would have subtitles in the new file.
 My guess is that you have both audio and video set to Copy mode, which streams from the old file to the new and bypasses all the filters. You need to set video to a new container type (e.g. AVI), configure the encoder for the quality you want, then save the new file.Read my blog here.
	Thanks for reply,a bit lost here,can you elaborate more,or direct me to a help site,
 afraid im no expert with this program,but can see that video and audio are indeed set to copy,the drop down menu gives me the options mpeg 4 dvd svd etc...but im lost.
	Choose mpeg4 asp xvid. You can leave the audio as copy.
 But where did you add the subtitles? I guess you want burned in subtitles and then should you add it under video->filters->subtitles.
	Yep, set to mpeg4 asp xvid,left audio as copy.
 then i went into video menu,and add subtitles,took srt file from folder that had original avi file and a separate file for subs.
 looked in preview and the subs are showing at bottom of movie...
 Then save video,but after a short process time,the new file still does not show subs (not in media player at least,even with subs on option)
 I have not done any configuring during any process.
	Finally managed to do it,i think where i went wrong was,
 after loading movie into avidemux,i was told "unpacked bitstream detected"
 This time i did not unpack it,and went through the routine of adding subs in the usual way.
 Im sure this was the only thing i did differently.
  How to Add subtitles to avi Xvid files !!!!By prithvi in forum Newbie / General discussionsReplies: 11Last Post: 12th May 2011, 10:05
  permanently add subtitles to aviBy RZ_29 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2009, 10:57
  Add Subtitles To AVI From DVD SourceBy Blue_3 in forum DVD RippingReplies: 9Last Post: 1st Sep 2008, 13:39
  How to add subtitles to AVI?By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 15:10
  add Optional subtitles to AVI files?By pck76 in forum MacReplies: 1Last Post: 17th Nov 2007, 19:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
