I checked some of the posts here in VideoHelp.com. They all said that if you want the subtitle shown when watching a .ts file, you must first extract the subtitle from the .ts file into a separate file. That means you must prepare two files. Is there really no better way to simplify the job? For example, is there a program that can play the video with audio and subtitle shown without making any extra subtitle file?
My present situation is that I have some .ts files recorded from my digital TV recorder. The .ts file contains video, 2 audio tracks (English and Chinese) , and a subtitle stream (Traditional Chinese). It contains some commercial ads with no subtitle. The subtitle is for the TV show. Without extracting a separate subtitle file, I successfully play the video with selected audio using KMPlayer, VLC Player or Media Player Classic Home Theater. The only problem is that no subtitle shown can be shown. What is the easiest way to solve the problem?
Please help. Thanks a lot!
	Those subs should work. Try install haali media splitter and play with mpchc. And be sure to enable the subs under play->subtitles or navigate->subtitle language or play->filters->subtitles in mpchc.
  Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31
  How to play multiple VOBs and a subtitle fileBy kenj in forum Software PlayingReplies: 3Last Post: 22nd Jun 2010, 18:42
  WMP 10 won't play avi with subtitle file.By zlmdlo in forum Software PlayingReplies: 1Last Post: 14th Dec 2009, 05:22
  how to split mkv file and subtitle file to play on blu ray via hdd usbBy julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28
  Avi file wont play when playing with .srt subtitleBy cudencuden in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 21:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
