First off, forgive me if I don't always use the right technical language. I'll try to explain everything in a way that people who know about this stuff will get what I mean.
I've had a Westinghouse HDTV for a few years, never had any problems with it. Recently, I bought a Vizio Blu Ray player (first time I've ever hooked up a Blu Ray player to this TV). I also have basic cable and a Nintendo Wii, which have been hooked up together for a while with no problems.
So right now I have the Vizio, the Wii and the cable TV hooked up. Vizio with an HDMI cable, Wii with the three-pronged, red, white and yellow cord and cable with the cable hookup the cable compnay provided; just basic, standard.
About a week after all this was set up, I started noticing occasional pink and green snowy static on the picture. At first, it was only when wathcing TV. Then it popped up while my son was watching a DVD (not a Blu Ray disc, but on the Blu Ray player). It still happens only occasionally, and still mostly while watching TV. I've yet to notice it while watching a Blu Ray disc.
So: any ideas? I did a little research and it seems the HDMI cable could be the issue, but then why would it happen while watching TV, which runs through another cable, with the Blu Ray player off?
I really hope it's not my TV. It does seem like a strange coincidence that it started happening right after I changed over to the Blu Ray/HDMI setup.
Thanks for any and all suggestions!
Probably not an HDMI problem. Faulty HDMI cables show pixelation or fail to lock at all.
Is your cable TV coming from an RF coax or other? Is there a cable box? Pink and green issues are often related to tuner issues or NTSC decoding errors. This shouldn't be happening on the HDMI input.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I know this is slightly off topic but you do know they have component cables for the Nintendo Wii? I have one and I have a westinghouse hdtv that has two component input connections. The component cable adapter for the Wii will cost a little bit but you will get a better picture than the regular rca cables that come with the system. Just fyi.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yeah it's an RF coax, provided by the cable company. No cable box. It has mostly happened while watching cable TV, but as I said occasionally while watching DVDs on the Blu Ray player. Never, so far, while watching a Blu Ray disc. If it's a tuner or NTSC decoding error (don't know what that means, BTW
have any suggestions for something I could do to fix it?
Thanks so much! -
It would be a TV malfunction. If it just happened on the RF input I would suspect the TV tuner or NTSC decoder.
If you are certain it is happenting over HDMI also, that points to a more serious TV failure.
Usually problems like this get worse over time. One thing I would try is remove all inputs except HDMI and continuously play a disc. If the problem is seen without any RF cable or composite Wii connections, then I'd take it to a service shop.
If the problem isn't seen with just an HDMI digital connection, you may be able to use the TV with an HD cable box (HDMI out) until you can afford a replacement TV.Recommends: Kiva.org - Loans that change lives.
You could also try just the cable RF connection again without the Wii or Blu-Ray player connected. If you see no problems, then the malfunction is due to interference between mixed RF, analog and digital inputs. This is still a TV problem but you may be able to live with connecting only one input at a time.
New JVC Blu-ray recorder for HDTV? (with 500GB hard drive!)
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Aug 2010, 21:37 -
Streaming HD movies to HDTV from downloaded Blu-Ray source
By embreeb in forum Media Center PC / MediaCentersReplies: 1Last Post: 12th Dec 2008, 04:46 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
Playing Blu ray & HD dvd on 42" hdtv
By namronthegreat in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Feb 2008, 20:23 -
Backing up DVR HDTV to Blu-Ray w/DVD audio track
By pulsation in forum DVB / IPTVReplies: 8Last Post: 15th Jul 2007, 04:54
