My ancient VCR/DVD combo finally kicked the bucket. So I did what all poor college students do and high-tailed it to Wal-mart to pick up a basic $30 DVD player. I got the Magnavox dp100mw8b. I have an older TV connected to a Comcast cable box. Initially the hookup seemed ridiculously easy -- I plugged the red, white, and yellow plugs into their corresponding holes on the DVD player and the cable box, then plugged the DVD into the power outlet. And....nothing.Well, the DVD player is getting power but I can't get any sort of picture. I tried every way of switching inputs on the tv and cable box that I could think of, but nothing happened. The TV, being an older model, doesn't have the red-white-yellow inputs. Any ideas?
If the TV does not have audio/video inputs, what do you have the audio/video cables plugged into coming from the dvd player?
The cable box ?
Because usually the audio/video jacks/plugs on cable boxes are outputs, not inputs.
If your TV only has the basic cable input, where you screw the one cable wire into it, you would need an RF Modulator.
http://www.amazon.com/Recoton-DVD-647-DVD647-RF-Modulator/dp/B00005T3FO
You can pick them up pretty much anywhere, radio shack, best buy, walmart, ect.
http://www.walmart.com/ip/Belkin-F8V3063-RF-Modulator/13072965#ProductDetail
Allows you to use peripherals with TVs that have no audio video jack
Delivers a sharp, bright video picture through S-video outputs
Designed to save space
RF Modulator to connect your AV equipment through your television's RF jack
Compatibility Devices: DVD Player, Video Game Console, Camcorder, TV, DVD Player, Video Game Console, Camcorder, TV -
Please next time you post use a title with a better description of your problem,for this time i changed it.
Headrest DVD player, POWER ACOUSTIK HDVD-93BK
By Skip Talker in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2013, 09:13 -
Blu Ray Player Vs DVD Player upscaling picture
By mukeshs in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th Dec 2010, 03:21 -
How to dezone a Mac Power book DVD Player?
By Romain in forum MacReplies: 22Last Post: 17th Jun 2009, 05:33 -
DVD Player with USB HDD (Non external Power) support
By fayewolf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jan 2009, 22:10 -
Power DVD : picture hidden behind black screen???
By HBM in forum Software PlayingReplies: 2Last Post: 14th Sep 2007, 02:43
