Hi, I can get ATI AX800 card from ASUS that has ATI Rage Theater 213RT1ZUA43 chip that is suppose to be 10bit?
I also have Leadtek FX5700 VIVO card with SAA7114H 9bit chip.
Is it worth to get the ATI ? Will the capture quality improve?
What about TerraTec G3 it's more than used ATI AX800 what about capture quality?
http://www.terratec.net/en/products/technical-data/produkte_technische_daten_en_92417.html
Ati have 12bit ADC. Both chips were old and have similar performance. With composite Saa chip is better. About Terratec I don`t know.
Is worth to buy a card with newer ATI chipset like Theater 550/650/750.
Do some test with Leadtek and see if is fine with your sources (?).
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Capturing VHS with ATI TV Wonder HD600 PCI card
By CamaroDMD in forum Capturing and VCRReplies: 12Last Post: 17th Jun 2010, 07:58 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
What Capture software can I use with the NVIDIA NVTV PCI TV Turner card
By JAYEDIN in forum Capturing and VCRReplies: 3Last Post: 19th May 2009, 00:55 -
Graphics card for video editing. ATI or Nvidia?
By vid83 in forum ComputerReplies: 2Last Post: 6th Feb 2009, 15:29
