So can you edit your own thread titles in this new forum system? I know you used to be able to in the old php system.
I was wanting to put an addendum on a thread I just started.
Results 1 to 13 of 13
Yep, click edit and go advanced and it should work.
thank you baldrick. I will check it out.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I just tried it on an old thread of mine and it didn't work.
Clicked edit on the first post - Go advanced - Changed the thread title (wanted to mark it solved) - Clicked save changes - Edited post still looks the same with the old title.Donadagohvi (Cherokee for "Until we meet again") -
Thank you baldrick. By the way I was able to edit my recent post on the first try immediately after baldrick's first reply yesterday.
Still not working for me. Tried on two threads now.
Can confirm that it works on a thread created within 30 days. For most cases this would be sufficient.
if you want to try and make it unlimited you could try changing it to something like 999999999
see this
http://www.vbulletin.com/forum/showthread.php?266042-Thread-title-editing&p=1535515&vi...=1#post1535515
Thanks BaldrickDonadagohvi (Cherokee for "Until we meet again") -
No sense in making it unlimited. For the most part, it's going to be:
OP: "Need help from an expert!"
1st answer: "Change your thread title if you want any help"
OP: "Need help with audio sync"
If the problem is "solved" after the limit, the solver could just write a (simple) guide. While the "How do I do this [SOLVED]" is nice, it's not absolutely necessary.
edit thread yep yep!
By testlongusernamer in forum TestReplies: 2Last Post: 20th Oct 2011, 19:26 -
Pioneer DVR-530H. Unable to delete or edit some titles.
By Baloooo in forum DVD & Blu-ray RecordersReplies: 7Last Post: 20th Mar 2011, 00:15 -
Creating a short-cut icon/link to [+ Reply to Thread] in forum listings ?
By vhelp in forum FeedbackReplies: 1Last Post: 5th Jul 2010, 18:57 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Filter out the terms Newbie and Pro from thread titles
By Supreme2k in forum FeedbackReplies: 29Last Post: 25th Aug 2009, 00:56
