Hi,
I have a Philips DVP3260 DVD player and this player worked without any errors since month. Also I have updated the firmware with http://vb6rocod.lx.ro/dvp3260_12.php
But since yesterday something strange going on. When I power on the dvd player it always "sends" play/pause signals in random periods.
E.g. when I start to view a movie I see that by OSD display in upper right corner of the tv.
Pause icon... then Play icon... 20sec I can view the movie... then again Pause icon for x seconds... then Play icon... and so on
What can I do?! I don't think thats a firware problem (because the player worked without problems for month with that firmware from vb6rocod).
Results 1 to 11 of 11
does the same thing happens when u use the USB to watch movies?
it could the players is going bad,or dirty
clean the lens and see what happens -
yes, happens on dvd's and when i watch a movie from an usb stick.
I'm no "engineering consultant" so is there a guide out there how to clean the lens? Where I find the lens and so on...
Thanks -
I also thought that the remote control goes crazy and sends this play/pause signals but that's not the case
For example when I push the play/pause key direct on the player and hold that key up to ~90% the play/pause craziness is away and I can watch the movie. But sitting 30cm in front of the dvd player/tv and push & hold the play/pause key is not my prefered way of watching movie
I was thinking it could be the remote or something else in the room causing the spurious pauses. I would still cover the IR receiver to see if that changes anything. By standing in front of the player and holding the play/pause key maybe what you're really doing is blocking that other signal.
How to switch back to original firmware?
Do you have a download link? Can't find original fw on vb6rocod's site.... -
They might (especially if the firmware version is different from the version the player was shipped with). However, it should only matter if you have custom/hacked firmware installed, or a bad firmware update (=bricked player, most likely). Otherwise, as long as you have the official/unaltered firmware installed, Philips shouldn't have any problem with it.
Neatvideo strange behavior
By themaster1 in forum RestorationReplies: 51Last Post: 12th Feb 2012, 09:11 -
AC3 6ch audio strange behavior in AVISynth
By lovyagin in forum Video ConversionReplies: 10Last Post: 1st Mar 2010, 11:17 -
LG DN788 ~Very Strange Behavior~Need suggestions
By buffee in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Feb 2010, 19:22 -
Strange behavior of the 5990
By ahhaa in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Aug 2009, 12:27 -
Strange behavior of Outlook Express
By ahhaa in forum ComputerReplies: 4Last Post: 27th Jul 2007, 10:29
