Is it possible to make the audio repeat throughout the video, in MP4 or MKV? I don't mean editting and expanding the audio manually to the video's length and encoding, I'm talking about making an already-encoded 6 minute audio track repeat forever throughout the 90 minute video.
'This possible?
Results 1 to 10 of 10
Nonono, I don't wanna add additional tracks, I want the same track to repeat. The goal here is economic storage of the audio.
You talking about looping the audio to where it would play continuously throughout the video (non-stop)? If so, you may want to check out some DJ programs.
It Started In Texas -
Correct.Originally Posted by V Bot
?Originally Posted by V Bot -
If you want to add this track to your mkv file, I would suggest loading the 6 minute audio track into Audacity, copy it and paste it repeatedly until you have the required running time, save the new file, then use mkvmerge to add it to your mkv video.
Ig you just want the audio to play back independently of the video in a live function then google for VJ software, which will let you live mix audio and video, and will allow you to what you want.Read my blog here.
Are you ******* blind?
Originally Posted by Xpenguin17**** it, it's not possible and I knew it way before I posted this thread. I really don't know why the hell I keep asking about the obvious...Originally Posted by Xpenguin17 -
Probably not possible - all containers that You mentioned are for transmitting sequentially audio and video data - looping should be made at the device level
Exactly.Originally Posted by guns1inger
I'm trying to fit a 720p movie into 700 megs, which so far is high quality if all the bitrate is allocated to the video, and since most of the audio is sparse commentary and a repeating music track, I wondered if this could've been economically encoded. Oh well.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 10:26 -
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25 -
Audio Out of Sync/Too Short for AVI Video
By nmycon in forum AudioReplies: 2Last Post: 4th Jul 2007, 22:00
